Home > Faults & Fixes > Fuel leak 3.6 TDV8 - leak off pipes
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Suspected fuel leak from under bonnet area drivers side - eventually tracking all over the underside and dripping on floor when engine running. Striped down and removed the metal plate mounted on the rocker cover
Discovered fuel leak at leak-off pipe and upon removal found o-ring seal in very poor condition.
New seals ordered and hopefully a pretty easy fix for once !
Note - be gentle with the return pipes as they are only plastic !
Post #639302 Thu Feb 01 2024 7:27pm
