![]() | Home > Faults & Fixes > L320 2.7td v6, P0087 |
Markon1986 Member Since: 21 Apr 2022 Location: Maribro Posts: 2 ![]() ![]() ![]() |
My Land Rover Range Sport 2007 year
James s m Member Since: 16 Nov 2023 Location: Highlands Posts: 21 ![]() ![]() |
Hi was wondering if you ever found the cause if this issue as I am experiencing something very similar with my car it throughs up high and low pressure fault codes causing limp mode on hard acceleration. It has been at the local Land Rover dealer three times now over 6 months and they can’t fix it after changing both high and low pressures pumps ,injectors , sensors, ECU , and lots and lots of wiring tests. Any suggestions? Thanks James |
Hi “ Lrstaylor “
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Yeah that's what we thought the car came to us with a new pump fitted some months later we replaced the pump for a euro car parts new pump still had p0087 but only in colder months come the summer it ran faultless.
Well unfortunately we have been chasing this fault for 3 years now |
