![]() | Home > Faults & Fixes > Range Rover Vogue 2011 |
Bigbill2656 Member Since: 26 Jan 2024 Location: Aberdeen Posts: 7 ![]() ![]() |
Any help would be appreciated also I’m in the Aberdeen area most the time if you know someone there.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
I've had my RRS for nearly a year now, the previous owner had an oil and filter change done on the gearbox just over 10000 miles beforehand by an indy using genuine LR parts/oil.
Thanks for that what area was that done as I’m in Birmingham at the moment?
Hi Bill,
Thanks anyway 👌 |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
Gearbox manufacturers recommend changing the oil at around 75k miles. The people who said if it's not broken leave it alone shouldn't be servicing landrover products. It's all about preventive maintenance. 2010 RRS, TDV8
Thank you my thoughts but trying to get in touch with someone around Birmingham or Aberdeen. Heard about Ian but not managed to contact him yet 👍 |
He's coming to me on the 20th Feb to do mine for a second time and my new neighbours D4. I had it done at 60k in 2018 and I'm now on 106k, also as mentioned above just preventative maintenance. A little bit far from you though. I'm reliably informed he resides in Telford.
Thanks I have that number and tried it a few times yesterday and left a message maybe he’s away at the moment. I’ll wait and see if he calls back. Thanks again👍 |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
Bodsy did mine at about 80k miles. Did both front and rear diffs also. Good service. Cant say I noticed any difference but it was done for preventative reasons. RRS HSE Dynamic SDV6 2014
Thank again I have been trying to contact Ian my be he’s away or something but no reply as yet. |
Take it to MMP in Dundee. Mikey will sort it.
