Home > Technical > L320 rrs heated seat
Ray1979
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
L320 2009 non facelighg
drivers heated seat help
Push button and that lights up but no heat in seat at all. Passenger side works great. All the seats working apart from heat anyone had this and can shed some light on where to start plz. Fuses r all good
Post #639029 Mon Jan 22 2024 7:38pm
If the fuse is ok, I would be inclined to start by checking the element is not burnt out, not unheard of.
Post #639032 Mon Jan 22 2024 10:36pm
Ray1979
Fuse is all good one under bonnet and in car checked most fuses. Light for seat comes on
But will double check tomorrow. Checked wiring tonight took seat out and all wires look ok under seat
Was going to run direct to heat pad but haven't found a wire diagram so not sure where or what wires go to elements themselves
Post #639033 Mon Jan 22 2024 10:41pm
No certain this is the correct one but I think it is pre-facelift, might also be l/h/d, but not sure that would make any difference. Probably have to view in "my gallery" to enlarge.
Post #639034 Mon Jan 22 2024 11:20pm
Ray1979
Cool thank u gives me somewhere to start
Post #639035 Mon Jan 22 2024 11:26pm
The heating elements are split in to two bits - one for the squab and one for the seat back - but they're in series so if one fails you lose the lot. Not unheard of for them to burn out (had that on my old RRS) but you usually get a very hot spot for a while before it fails. 2012 SDV6 - it's missing a couple of cylinders
Post #639053 Tue Jan 23 2024 12:48pm
Ray1979
I just have nothing at all at drivers side only owned about 7 months so could have burnt out possibly before I owned it is there anyway to run power direct to see if they work themselves
Post #639055 Tue Jan 23 2024 12:52pm
Unplug the element and do a continuity test on it, surely that must be the easiest option. Just look under the rear of the seat base and you will see the wire coming through the metal pan from the base, just unplug it and test.
Post #639072 Tue Jan 23 2024 9:10pm
Ray1979
Thank u ill give that a try tomorrow. Went and picked up another amplifier tonight for stereo as mine only turns on when it feels like letting me listen to music. So will fit that and try seat again.
Post #639073 Tue Jan 23 2024 11:03pm
