Home > Faults & Fixes > Suspension out of tolerance
Hullrrs
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
Decided to try and level up my rrs last night big mistake
Started the hight calibration when I put in the valves it’s comes up out of tolerance each wheel must be within 3mm and tries again
Still same
Now I have the red light on dash and off road hight only
Buttons do nothing
Where have I gone wrong?
Using icarsoft v3.0
Please help
Post #638990 Sun Jan 21 2024 1:33pm
NoExpert
Tire pressures correct, 2.3 bar front, 2.5 bar rear?
Are the sensor arms moving freely and all attached?
Can you get live data showing the height at each corner?
Does one corner look/measure lower/higher than the rest?
You can fudge the numbers a little by adding/subtracting 5mm if you see you have a problem corner. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #638992 Sun Jan 21 2024 1:46pm
Hullrrs
Thanks for the reply
Tyre pressure all correct
Sensors moving freely
All corners now measure level after it goes to off road then normal hight
Then put the measurements in and comes up out of tolerance must be within 3mm but fronts measure 460mm both and rear 465mm both
When I put these in it say again out of tolerance try again
Driving me mad
Front left 4
Front right 11
Rear left 0
Rear right 25
All must be within 3mm
Post #638994 Sun Jan 21 2024 2:00pm
Hullrrs
Well after about 10 attempts I’ve managed to get rid of the fault and cars now at normal hight but left side sits 4-5 cm higher.
Terrified to try again so will just leave for now really wish I hadn’t bothered
Also it says slow to rise and will rise when cooled so assuming I’ve shafted the compressor running it up and down trying to fix it
Good job I love these cars
Post #639001 Sun Jan 21 2024 8:24pm
Hullrrs
Evening everyone looking for some help again
Fed up of the car leaning so decided to re calibrate suspension again
When I go into calibration it opens the valves front and back which I assume should level both sides out ?
I could be wrong
Problem is mine doesn’t level out on passenger side which is the same side that sits higher
I’ve managed to calibrate it by smudging the figures and now sitting much better but not level about 20 mm out higher front and back on passenger side
What would cause this ? Any ideas
I’ve searched and searched but no one seems to post the actual fix just the problem
Hopefully I can get this sorted for myself and others. it’s driving me insane
Post #639585 Sun Feb 11 2024 6:05pm
