AcePratt
RRS HSE 3.0TD 2010 Park heater not working | |
Hi All,
Had my PH enabled last week, but it fails to operate off either the timer option or the manual heat option. Timed and manual vent are working fine. Also the FBH is operational and working as it should.
FYI if I select manual heat, the touch screen does show this is selected, but nothing happens. If I start the car for a minute or two, then switch off and select manual heat, the heater fans activate and the FBH remains on, as it would anyway when the engine is still cold. However the FBH switches off after a few minutes, leaving the heater fans still running for the half an hour....
I have checked with the dealer to ensure the CCF has "Park Heat" selected and he assured me it was. I have also checked and charged the battery overnight to eliminate this possibility. The car is 3/4 full of fuel.
Lastly I have an error code "lost coms with aux heater control module". So I'm wondering if I actually have the control module fitted, but I do not know where to locate this. I'm guessing the right rear quarter behind the boot trim, I have had a look but as I only have a small viewing door, I cannot say either way!!
Any ideas?
Fri Jan 19 2024 7:11am |
