Home > Faults & Fixes > Rear reversing camera stopped working |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
It will be down to the trailer programing, I had a faulty parking sensor on the front and it stopped my cam working |
Mon Jan 15 2024 2:00pm |
Scribbleuk Member Since: 14 Sep 2023 Location: UK Posts: 5 |
Thanks - I assume this is easily detectable with Dealer diagnostics? Or will they need some "coaching" as to where to look to solve the problem? |
Mon Jan 15 2024 2:22pm |
I'm sure when it happened to mine I lost both parking sensors and camera. my Gap tool showed a faulty sensor but not a faulty camera so I replaced this and it worked again. How are you programing the trailer? If your using the gap tool just reset the car. All will be back to normal |
Mon Jan 15 2024 7:05pm |
Just trying to configure it via the infotainment system. But it seems to be stuck partially configured. It can’t complete the step where you are meant to attach the parking dots to the trailer because the camera has stopped working, and for some reason it is impossible to delete the trailer. I’ve tried a reset of the system but it’s still stuck. Don’t have access to a Gap device. |
Mon Jan 15 2024 7:54pm |
