![]() | Home > General (L461) > Remote Climate Control Issues |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
My L494 2015 RRS has the remote heating controlled via the app and mine only turns on or off, no control of the temperature but it has always been like this. Would it get to the temperature that’s set on the dials in the car? |
rbt1974 Member Since: 17 Nov 2023 Location: London Posts: 5 ![]() ![]() ![]() |
it should show target temp (and actual) as it shows in the app store.
Mines a 3.0l SDV6 AB. I’ve used the app for almost 7 years with this car now and it’s always been the same just on and off with no target temperature. I did think the newer models had the target temperature on the app though. Have you tried logging out and then back in on the app. If this doesn’t work maybe delete the app then re install it. At last then you will get the latest updated app. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1876 ![]() ![]() |
There is only one app and mine has an option to select temperature, not sure it was there in earlier versions?
