Home > General (L494) > Hard brake pedal, car won’t start off button |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 18 |
My take on it is, if the pedal goes hard then the stored vaccum is leaking/bleeding out.
Sun Jan 14 2024 5:32pm |
Mac35 Member Since: 15 Dec 2023 Location: Angus Posts: 43 |
Sounds like a vacuum leak or at least lack of vacuum to assist the brake booster. |
Sun Jan 14 2024 5:55pm |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 64 |
Thanks for the replies, will have a good look at the system and see if anything stands out. Guessing that if it is a potential seal issue you would need to change the whole unit.
Sun Jan 14 2024 9:13pm |
is the problem there all the time or when the car is not used for time i.e. overnight? |
Sun Jan 14 2024 9:19pm |
It doesn’t happen all the time, and the brakes seem unaffected.
Sun Jan 14 2024 9:31pm |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 |
I had this problem with my car. On two occaisions it failed to start entirely and had to be recovered to the dealer. First time it was with them for three weeks as they couldn't solve the problem but then seemed suddenly to start so i got it back. Second time after a few days with them I was told there was a faulty/corroded wiring connection underneath the car which they had fixed. So back on the road again although the problem of not starting first time soon reappeared. This coincided with finding out that there was no news on when I'd get my new car after waiting for a year. I cancelled the new car and got them to buy back my car as I'd completely lost faith in it. Tim
Sun Jan 14 2024 11:03pm |
Did you have the hard brake pedal symptom as well? |
Sun Jan 14 2024 11:35pm |
Yes, I did. Garage couldn't convince they knew what the problem was so all confidence disappeared as did the car shortly after. Tim
Mon Jan 15 2024 12:13am |
I wonder if you bought my old car? Is it a dark blue P400with ivory interior? Tim
Mon Jan 15 2024 12:15am |
No mine is a 2016 Yulong white Autobiography.
Mon Jan 15 2024 7:01am |
Sorry but I really don't know if that might be the cause. As said the dealer was unable to explain what was wrong with the car to me after prolonged and I guess expensive investigation. Fortunately the work was covered under warranty. Tim
Mon Jan 15 2024 10:38am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 483 |
Just curiosity, do you just give the start button a quick single hit or hold it till the car starts? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Jan 16 2024 6:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Not able to comment on the L494, but it makes absolutely no difference to my old L320 if there is vacuum in the brake system or not it still starts first time.
Tue Jan 16 2024 6:58am |
Hi Drago,
Thu Jan 18 2024 2:53pm |
