![]() | Home > Faults & Fixes > Few little faults to scratch your heads at with me |
It may be worth checking your battery connections and earth points regarding the electrical issue 2010 RRS, TDV8
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 ![]() ![]() ![]() |
Hello gogsy1956, tyne and wear too I see.
Aye, wallsend to be exact,, you should be able to upload video just as you do with pics 2010 RRS, TDV8
Im not sure i know how to do that either, still a newbie |
?si=tjmFYwZOPOytmToV
Maybe it’s trying to get the music to stop?
I dont blame it, was just crap on the radio.
Quick update.
Have you checked the wheel bearings? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yes, both front wheels bearings have been replaced recently. The osf bearing i didn't personally replace, but it looked new, nsf I have replaced although they werent genuine land rovers so the quality wont be as good but were off LR PARTS so assumed they would of been sufficient.
Hi all,
So trying to think of rotating things that get warm. You reference it does it in reverse and more apparent when it's warm. So speed can be dismissed I think. Have you considered wheel bearings or the transfer box. The prop shaft hanger bearing? You may be able to find a way of putting your listening ears on the TB. I'm probably wrong as I usually am but I'll suggest it. 2006 2.7 TDV6 HSE in Cairns Blue. |
There are no right or wrong answers and i thank you for your suggestions. I will be listening in again to front hubs i think. perhaps find a different place to clamp to. And yes i think i will probably put one on TB too
Rear wheel bearings checked? Sounds crazy, but I’ve had what I swore was a front end noise turn out to be the back. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
