Home > General > Air Mass Trunking
Jollyswagman83
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Air Mass Trunking
Hi Everyone
First time post here.
I have a RRS 2013 (2005 - 2013) 3 litre diesel HSE.
Had it six months and the other day it went into the Restrictive Performance Limp Mode.
Managed to get the AA out to take a look and they have come back with the following in their report:
"Error sporadic.Air mass trunking , worn on clip temp remove re fit and cable tie in situ .Mbr has brc and requires new trunking and clip fitted asap"
Is this a straight forward job to do, is it something a layman can do or does it require a mechanic? The reason i ask, is every garage at the moment seems to be fully booked for the next 2 - 3 weeks.
Thanks in advance.
Post #638670 Wed Jan 10 2024 1:03pm
Well if you watched the AA guy temp fix it? I guess you know?
Or did he point the the problem pipe?
Post #638673 Wed Jan 10 2024 2:16pm
Jollyswagman83
No he couldnt fix it roadside due to parts etc. Instead attached a cable tie to the part to temporarily hold it in place.
Post #638674 Wed Jan 10 2024 2:18pm
