Home > Maintenance & Modifications > L320 5.0 SC Rear Brake conundrum
Cjrob
looking for some help with rear brake pads / discs for a 5.0 2011 SC RRS as the pads I ordered don’t seem compatible with my discs (pads are way too big) confirmed with 2 separate suppliers that the pads are correct for the car - Brembo Front, TRW rears
the current discs measure 350mm – confirmed as they are part number SDB000646 (stamped on the disc)
the pads I have are brembo P 44 025 – compatible with part number LR025739 – which I believe are correct.
What I think has happened in its past is the wrong discs have been fitted (350mm) and not the 365mm, but when you compare the current and new pads, they are totally different, the current pads just clear about 90% of the disc.
Very confused - can anybody shed some light on this?
Post #638537 Thu Jan 04 2024 3:34pm
Disco_Mikey
Current discs are wrong. Too small
Correct part number is LR016192. Supplied pads are also correct for 5.0 SC
Post #638541 Thu Jan 04 2024 5:42pm
Looking at the state of that disc, I'm surprised you haven't ordered new discs too. At least then you get the correct disc and pad working together. 2012 SDV6 - it's missing a couple of cylinders
Post #638549 Fri Jan 05 2024 10:26am
I can't see anything wrong with it from here Laughing
Post #638553 Fri Jan 05 2024 3:27pm
