Home > Maintenance & Modifications > Air suspension problem for a change
chrbro
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
If I park my 2010 l320 slightly uphill the NSR air strut loses all pressure and that wheel disappears into the wheel arch. If I park it the other way round, slightly front end down, nothing, stays up all ok
Any ideas ??
Post #638506 Tue Jan 02 2024 8:05pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
The RRS always tries to level itself. If it's rocked by the wind it will go on resetting to the height of the lowest wheel until it bottoms out.
Park it on the level and then pull fuse 3 from the under-bonnet fuse box, which disables the air suspension ECU. If one corner goes down, then you either have a leaking air bag or a seal somewhere.
Best of luck.
Post #638550 Fri Jan 05 2024 12:07pm
chrbro
Cheers I'll have a go
Post #638578 Sat Jan 06 2024 4:02pm
