![]() | Home > General (L494) > Headlight aim too high?? |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 22 ![]() ![]() ![]() |
I don't think it's anything you need to worry about.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
Disabling it before the MOT could be a good idea. |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
This may help….really easy to lower them…
Thanks, just read your post. You say you set the height of yours facing the garage door. Is there a correct height I need to be measuring and marking from the floor? |
Unfortunately I don’t have any measurements however you can easily see them being turned down … gave them a few tweaks which solved the problem but I could still see clearly and I stopped the flashing headlights from oncoming motorists.. never had an issue with MOT either!
