![]() | Home > General (L494) > Air bag light staying on |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Take the car for a short drive & see if it resets.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
I’ll take the car out tomorrow after work and see if it goes out. I spoke to the AA man who changed the battery and he said the same , take it out and see if it disappears and to let him know the outcome. He did say he will come back out and reset the air bag light if need be. Thanks for the reply |
I’ve been out today for a short drive. The air bag light come on after a couple of minutes. I drove another couple of miles with it on the pulled over , turned engine off then back on again and it has not come back on. Hopefully it’s sorted itself out…. |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
Battery change provokes a lot of temporary errors that then stay in the memory.
Mmmm I’ll monitor it over the next few days and see how it goes…….. |
Just another thought - when I had a Vogue (L322) the airbag light had a habit of coming on and it was an issue with the expolsive battery terminal which was part of the airbag cystem - the yellow connectors seemed to get corroded & malfuction - don't know if the RRS has one though. 2006 RRS 2.7 HSE. |
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 55 ![]() |
Mine comes in intermittently when the drivers seat is moved!
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Possibilities also include: loose connection somewhere, or clock spring in the steering wheel. Barrie.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 420 ![]() ![]() ![]() |
In extreme cases to get an MOT( classic Jags) run a couple of wires to the back of the bulb and use a 10 second timer from ebay to short out the bulb Always listen to old people or when they die you will live on in ignorance.
Update on this, the air bag light has not come back on so I can only assume it was due to the battery change and now has sorted itself out. I think the battery may have been on its way out for a while now. The stop start system has started working again (not a good thing) and I’ve been having problems with the soft close doors and got some bits replaced under warranty and to be fair was still a bit hit and miss every now and again but now all working as they should so I’m wondering if the original issue with the soft close doors was battery related more than components. You would think a garage would check the battery condition as their first port of call for any electrical issues s in a car like these. Anyway all good now. |
bellcrank Member Since: 19 Jan 2015 Location: Kent Posts: 11 ![]() ![]() ![]() |
I've been driving around for the last 3 weeks with the airbag light on my 2017 AB, and just came across this tip, which actually worked for me! Thanks Mike |
