Home > Maintenance & Modifications > Gearbox Linkage "How To"
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Hi Guys got an issue with my 2010 facelift sport. Cant get it to go into drive, guess its the linkage thant needs fixing.
Anyone know of a "How to Fix" it guide or Youtube clip? Very Happy
TIA Thumbs Up
Post #638183 Mon Dec 18 2023 3:43pm
Oldandconfused
I think there is one on the Disco3 forum.
Before you change it, what I did was get underneath on ramps, drop the transmission guard and give it a good spray with penetrating fluid then work the lever back and forward. This freed it up nicely then a good dose of lube (cant remember if I used a silicone grease) has seen it right.
Replace the tranny guard of course.
Found it.
https://disco3.co.uk/forum/topic31656.html
Post #638187 Mon Dec 18 2023 5:56pm
Ken 153
Excellent 👍
Thanks a bunch.
Post #638189 Mon Dec 18 2023 6:09pm
Ken, out of curiosity would be interested to know if your car does have a transmission shield fitted, as my 5.0L doesn't have one fitted and never has unless dealer left it off in very early day's. Never been able to find one listed for it either just the 3.0L, bit late in the day to worry about it now but if it does just wondered if you can see any part numbers on it would be appreciated.
Post #638192 Mon Dec 18 2023 8:13pm
Ken 153
Hi Col Bow down
I'll let you know when I get under her tomorrow or Thursday. Thumbs Up
Post #638194 Mon Dec 18 2023 10:12pm
Hi Ken, appreciated that, many thanks Thumbs Up Plenty of 5.0L down this part of the world so if it should have one might not be to much trouble to find one in breakers yard.
Post #638195 Mon Dec 18 2023 10:33pm
Disco_Mikey
My 5.0 doesn't either. Also thought it odd, but JLR, so Confused
Post #638196 Tue Dec 19 2023 5:33am
Ken 153
Just managed to get under the car and I seem to have the cover fitted. I've found 5 bolts (2 x front, 1 x rear and 2 down the drivers side) be Censored if I can find the 6th one.
Anyone got a suggestion?
Sounds like its full of water too!
Post #638276 Sat Dec 23 2023 12:21pm
All very odd, but does it look like either of these, although the top picture is for the 3.0L, the lower one is a illustration from the 12/13 workshop manual, and shown for all variants, but could be just generic illustration I guess, as it lists that shield and brkt. for the 05-09 vehicles, which there was never a 5.0L version and a different transmission the 05-09 had a HP26 the 5.0L has the HP28, wouldn't know the external differences though if any.
Post #638297 Sat Dec 23 2023 9:52pm
Ken 153
Mine looks like this and is about 3 foot long
Post #638298 Sat Dec 23 2023 11:22pm
Ken 153
Post #638299 Sat Dec 23 2023 11:24pm
That is the Fuel Tank shield/cover I'm afraid not the Transmission shield, not sure I would remove the bolts unless you have a empty tank or the tank supported Laughing
Post #638300 Sat Dec 23 2023 11:40pm
Ken 153
[/img]
Post #638301 Sat Dec 23 2023 11:46pm
Ken 153
whoops, better put it back, where should I be looking?
Post #638302 Sat Dec 23 2023 11:47pm
You should be looking forward of this X member.
Gearshift linkage.
Post #638303 Sun Dec 24 2023 12:06am
