![]() | Home > My Range Rover Sport > Another 1st time RRS owner |
MHSPORT08 Member Since: 13 Nov 2023 Location: South East Posts: 38 ![]() ![]() ![]() |
Thanks for the Can Bus data info, seems a bit strange but I’ll try and get a more powerful reader on the car to see if anything can be found |
A few updates.
Might be worth changing the EAS relay - if the pump was replaced but the relay left, it has been known to throw an error (no idea why). 2012 SDV6 - it's missing a couple of cylinders
Good point there.
I ordered a compressor relay and its arrived but some more things have sprung up since.
A4j1s0 Member Since: 11 May 2022 Location: Gloucestershire Posts: 29 ![]() ![]() ![]() |
I had the same fault and it was a blocked filter on the exhaust side.
Great thanks for that tip.
The fresh air feed comes from the left hand side in the load compartment and has a filter on the top.
Thanks for those tips on the air pump feeds.
Ok I think we are there.
Small update, had the suspension height calibrated |
Done about 2k now and suspension seems good but it went into limp mode the other day on the motor way.
thegolffather Member Since: 07 Jun 2024 Location: Guam Posts: 13 ![]() ![]() ![]() |
Very interesting |
Small update:
