Home > Technical > Which compressor do I have fitted
AcePratt
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Hi Folks, I have a RR sport 2010 3.0 V6 and have a suspension light on the dashboard. I have had the RAC out and they diagnosed a compressor fault. I would like to see if thee is a re-conditioning kit available before plumping for the full cost of a replacement pump. However I do not know which pump is fitted to my vehicle. What I do know is that the pump is not mounted in the boot, it's underneath the car just in front of the rear wheel.
Does anyone know which pump this may be?
Thank you.
Post #637718 Wed Nov 29 2023 1:25pm
The problem is, if it has been changed before it could be either Hitachi or AMK, easiest way is drop the plastic cover and have a look, they have different mounting bracket's so easy to tell, if still original proably Hitachi.
Post #637724 Wed Nov 29 2023 3:57pm
NoExpert
If you see RVC500010 on the lower cover it is most likely Hitachi. The Hitachi covers won’t fit an AMK unless it’s some knock off unit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637731 Wed Nov 29 2023 8:40pm
I think you might find RVC500020 is the upper half, the number on the lower part you can see is RVC500010
Post #637735 Wed Nov 29 2023 9:52pm
NoExpert
Doh! Fixed it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637746 Thu Nov 30 2023 5:35pm
AcePratt
Thanks all,
Turns out I have the AMK fitted, new one is arriving shortly.
Post #637902 Fri Dec 08 2023 10:19am
