![]() | Home > General (L461) > Electric Range on P550e |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
1) because charge speeds are not linear. They taper off after 50/60% to ensure the battery’s long life. And remain slow of the battery is cold. Also; the input charge may not peak at 50kwh even if the charger says it can.
Phil B Member Since: 21 Jun 2012 Location: Bucks Posts: 19 ![]() ![]() ![]() |
Phil,
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Yes Octopus is probably the best supplier for price and customer support.
Sadly, seems the IO go does not work with my pod point charger and the MY24 PHEVs. If I select a P400e it says it’s compatible, but not with the P550e. Very strange indeed. |
I just use the schedule in the car/app to control when it charges.
