Home > General (L494) > 2016 L494 passenger rear door lock problem
Drago
I am currently having issues with my NS rear passenger door in that the door wont open.
This is from both the inside and the outside (with child lock disengaged)
Has anyone had a similar problem.
If so how did you get the door open?
I am guessing the problem is something to do with the door solenoid.
I can hear a clear locking noise when the car is locked/unlocked.
But unfortunately the door still wont open
I’m also not convinced I can remove the door card with the door closed, unless somebody knows anything different?
Cheers in advance
Post #608440 Sun Jan 10 2021 9:51pm
Grimble
resurrecting this as I have an identical problem L494 MY2014.
Was there a solution? RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #637595 Sat Nov 25 2023 11:48am
Grimble
Update
Repeatedly lock/unlock on the remote whilst thumping the door in the area of the lock with my hand got it opened.
After that a squirt of WD40 on the latch and all seems well!
Did all the other latches just in case.
Result! RRS HSE Dynamic SDV6 2014
Post #637597 Sat Nov 25 2023 12:37pm
