![]() | Home > Technical > Access to gearbox T40 bolts |
The gearbox fits many manufactures and isn't designed to be serviced in situ, or serviced at all!
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 32 ![]() ![]() ![]() |
Thanks Andy. Will check the bolt lengths but think the replacements are all the same M6's - have now checked and all the same. Bolts going back in were much easier than the T40's coming out - got a torque wrench on most of them except those behind the cross members.
Car in high suspension. Axel stands under it.
The cross member is supposed to be taken off for some of the access requirements around the transmission, that's why it's in the way. 2012 SDV6 - it's missing a couple of cylinders
Thanks but not touching/removing anything i don't have to on this thing - likely to break it or me.
Workshop manual here if you're going to be doing stuff yourself on your RRS: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
@Andy - thanks again - good tip re the access height - not something i've had before in road-going audi's.
If doesn't, purchase 2 tubes of Dr. Tranny or shudder guard additive. |
