![]() | Home > Technical > ARC Hydraulic Leak Repair Options? |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 ![]() ![]() ![]() |
I think it depends where the leak is from, I did read a thread on here once where it was leaking the pipes that were in the drivers side wheel arch and the poster used hydraulic hoses and coupling to fix. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Reading some of the previous posts, it is possible to change the pipes with a partial body lift, not complete removal of the body, currently I believe the pipes are on back-order not obsolete yet, however not sure there is a time frame as to when they may be available.
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Thank you! I’ve read these posts and it now makes more sense about the repair. Hopefully a solution we can at least try depending on where the leak is. |
