Home > Maintenance & Modifications > FBH Manual heat/vent problem |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Shortly after getting my L320 I enabled the FBH timed heat function. I set the two times (2010/2011 only have two time slots) and it runs fine at these times for 30 minutes as it should for the most part. The problem I encounter is if I get in the car, turn on the radio, access the Timed Heater function and manually turn on the heater or vent, it will run for exactly two minutes and shut down. If I then exit the car, some time later it will then run for the 30 minutes as it should have when I initially hit the button on the screen. I have tried this on both a cold and hot engine and get the same results. Would be nice to get this working correctly so I can run the manual heater rather than leaving my car idling in the street before putting my 15 month old daughter in the car. Any ideas what’s going on? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Oct 25 2023 2:40am |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 80 |
It is my understanding that in order for the FBH to kick in there must be:-
Wed Oct 25 2023 11:11am |
Think we’re talking apples and oranges. I’m talking about the manual option on the screen. My timed heater works fine, I just can’t get it to run more than two minutes on manual mode from the screen.
Wed Oct 25 2023 3:06pm |
