![]() | Home > Technical > Which ARC module can I use. |
Have you tried the install new module procedure on the steering angle sensor?
Jobe_joe Member Since: 10 Apr 2019 Location: Oldham Posts: 8 ![]() ![]() |
I’ve calibrated the steering sensors centrally and checked they don’t go past 580 degrees each way |
Try the install new module procedure. I’ve had multiple calibrations fail and then done the install new module procedure (reinstalls the software) and it works fine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
There is no install new steering angle sensor feature on the GAP IITool, just a calibration feature. I have since tried to recalibrate the ARC module which failed and has caused a red fault light, C1A00-54 (AF) due to ARCM missing calibration.
