![]() | Home > General (L494) > Retrofit Solar attenuating windscreen SVR |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 275 ![]() ![]() ![]() |
Don’t see why not - the solar attenuating bit is just an additional laminate in the screen. I had it on a previous Velar and it did work well to keep the heat out of the car. |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 184 ![]() ![]() |
as far as I remember, the SVR could also geht the solar attenuating windscreen as an option. therefore a retrofit should be possible without problem. check, if sensors or something have to be aligned I have it also on my HST and it reflects the heat very good. besides the ordered tinted windows from factory, I added an addition tinting from Stek (Stek Nex 70) on the panorama and the tinted windows. the addition tinting is not visible, but the heat absorbtion is impressive.. Range Rover Sport HST D350 |
