![]() | Home > General > Problem with gearbox L220 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
There is a emergency park release lever which you could pull which should allow you to at least move the vehicle. This maybe for a L/H/D, access to the lever maybe different on a R/H/D and under the cover by the epb switch not sure, but the lever should be there somewhere.
That’s for the 8HP70 transmissions with the rotary knob. This is a 2010 with a 6HP28 that uses a manual gear lever.
Stand corrected, could explain why I've never noticed it on my s/c |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 779 ![]() ![]() ![]() |
This one Col?
The 5.0SC’s for 2010-2013 all had beefed up 6HP28’s same as the 2010/2011 3.0 TDV6’s. Only the 2012/2013 3.0 SDV6’s had the 8HP70.
"The 5.0SC’s for 2010-2013 all had beefed up 6HP28’s same as the 2010/2011 3.0 TDV6’s. Only the 2012/2013 3.0 SDV6’s had the 8HP70."
I’m with you on the manual shifter, makes a very nice hand rest and in my opinion adds to the “Sport” feel. I wish I could get the fuel efficiency of the 8 speed with the shifter of the 6 speed.
If anyones running a 5.0L S/C L320 aerodynamic house brick I don't think fuel efficency is top of the priority list no matter which box it had in it. |
grimreaper Member Since: 18 Oct 2020 Location: Cheshire Posts: 18 ![]() ![]() ![]() |
thank you noexpert spot on with your diagnosis garage had service the Rangie and discovered that the gear shift was stiff so adjusted the bit underneath rang them monday and the garage sent the machanic out to sort it sorted it in about 10 mins so thanks again no expert. |
