Home > General > ACE pipe kit LR014592 unavailable, can I use RQA500018 ?
PhilnDeb
Hello all, I am looking at replacing the ARB bushes on my 2010 5.0 SC due to the dreaded creaking in hot weather, I noticed that my ACE front pipes are very scabby and am thinking it would be easier to do all at once with the body lifted but the repair kit pipes listed as part no.LR014592 as you will all know is unavailable, however when looking at the kit for the 2005-2009 (part no. RQA500018) the pipes and all parts look exactly the same, does anyone know if they will fit a 2010?
Pics of the pars diagrams
Post #633774 Fri Jun 16 2023 12:03pm
PhilnDeb
So the answer is yes if you get the flexible pipes that attach to the front anti roll bar replaced to accept your old fittings. Coet me £90 at a local hydraulic shop.
The rest of the pipes are the same and fit fine so if you are waiting for the set that is out of stock it may be worth thinking about.
Post #636351 Wed Oct 04 2023 8:44am
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
I'm in the same boat with this. Car has been off the road for a month and can't find a lr014592 to save my life. Could I get a bit more detail on how you resolved this please? I'm not quite clear on what you had your local shop do. Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #642634 Fri Jun 14 2024 11:14am
PhilnDeb
Hi I ordered part no. RQA500018 , this has the right connections at the block and the two to the cooler at the front, you will need to get a hydraulic shop to swap the hard pipe sections from your old pipes that connect to the ace bar onto the new pipes. This involves some cutting and soldering so I was a bit nervous but it turned out fine. In the pics you can see the finished set to show the shop. The other pic is the two sets before the swap. Get the shop to leave one side of each the fittings loose so that you can fit them first and them tighten them as the angle is important and this makes it much easier.
I used Preston hydraulics in Swindon, Wilts but they are a long way from you!
I think Island 4x4 was the best price for the kit but their website is a bit hit and miss. Good luck.
Post #642636 Fri Jun 14 2024 1:20pm
SuperC
Thanks, much appreciated. I'll have to get on to it asap. Cheers,
Stuart.
Post #642647 Sat Jun 15 2024 9:11am
