Home > Technical > Range rover sport l494 sdv6 no vacuum on bank 1
needle
hey all , got a weird one here
Range rover L494 3.0 sdv ,2015, had a Map sensor code come up P006A-00 then restricted performance, not convinced its that as the live data looked ok , Cant hear any intake leaks , looked at the MAF live data Bank 1 nothing and reading zero, Bank 2 reading ok .
Cleared all the codes went for a run ,same again
Took the MAF out both air boxes and bank 2 sucking like a hooker on steroids but not a thing from Bank 1 completely dead, away to do a smoke test but surely to feck would hear that bad a leak , what am i missing on this bloody rangie
Post #636034 Thu Sep 21 2023 11:39am
Disco_Mikey
The 2nd MAF will have no reading, as the secondary turbo was not spinning. Completely normal Thumbs Up
P006A is usually a boost leak
Post #636035 Thu Sep 21 2023 11:44am
needle
even when out for a run ? was redlining at times but still nothing from maf 1 during live data
Post #636036 Thu Sep 21 2023 11:55am
Disco_Mikey
What diag are you using?
Generic stuff is notoriously Censored on JLR stuff
Post #636043 Thu Sep 21 2023 3:01pm
needle
Autel 808
Post #636044 Thu Sep 21 2023 3:04pm
Disco_Mikey
If its not a boost leak, then better diag gear is required Thumbs Up
Post #636050 Thu Sep 21 2023 6:13pm
needle
looks like its the turbo shut off valve , tried exercising it with the autel and it opened slightly then gave me some vacuum then sh*t itself again , looks like its seized shut, freed it up and seems to be ok now
Post #636051 Thu Sep 21 2023 6:22pm
