Home > Technical > Wire feed ..engine side to glove box fuse box ( routing)
Pistnbroke
Have installed a 096 battery 72 AH in the RHS "empty space" under the RH cover. Am going to use a Voltage sensitive switch to charge it .
BUT I want to run my fridge when the engine is not running from the second battery via rear socket. So I need to rewire fuse 47 to take a feed from the battery (easy)
BUT how do you get a wire from engine side to the glove box fuses? Always listen to old people or when they die you will live on in ignorance.
Post #635704 Sun Sep 10 2023 9:41am
If you look at the bulkhead to the right of the brake servo you will see a grommet about 30mm diam. admittedly opposite side to the fuse box but quite easy to get to and thread a wire over the top of the trans. tunnel, I used it recently.
Post #635706 Sun Sep 10 2023 10:06am
Pistnbroke
Perfect..I was going to get my head torch out and look for something similar ....now I could get my oil pressure gauge feed through that !! Progress. Always listen to old people or when they die you will live on in ignorance.
Post #635708 Sun Sep 10 2023 11:37am
