Home > Maintenance & Modifications > ZF6hp26 swap
John R Hickman
England 2009 Range Rover Sport TDV6 S Santorini Black
ZF6hp26 swap
Are these transmission box's interchangeable between models? for example disco 3 2.7 into a sport 2.7 or 4.2sc into a 2.7 and how about the L322 disco 4 etc. I've been on the look out for a lower mileage example but not sure what will fit. I have a chance of one from a 4.2sc ffrr. I'd have to use the mechatronic from my own box with it. 2008 RRS 2.7 TDV6 S Poverty model
Post #635680 Sat Sep 09 2023 12:11am
I think the 4.2 maybe different.
Yeah I asked about using a D4. I think the answer was yes, but no guarantee.
Post #635687 Sat Sep 09 2023 7:15am
John R Hickman
Done some cross referencing and found that RRS 2.7, 4.2sc, 4.4 all have the same gear ratios the difference as i can see is the torque converter size. 255mm = 2.7, 260mm = 4.4, 280mm =4.2. Disco4 2.7 has same ratios and torque converter as rrs 2.7 and 4.0L has same but 260mm torque con. I can't find specs for the ffrr to compare though. 2008 RRS 2.7 TDV6 S Poverty model
Post #635695 Sat Sep 09 2023 1:01pm
The Supercharged (and TDV8?) had modified epicyclics in order to handle the grunt. But that wouldn't cause a problem if used in a lower output model. 2012 SDV6 - it's missing a couple of cylinders
Post #635726 Sun Sep 10 2023 8:53pm
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
You'll need to swap over the mechatronic unit also - e.g. keep the one that belongs to your car. Unless you feel like re-coding the new one to your VIN. That's the easy part of course! Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #635765 Tue Sep 12 2023 5:22am
