Home > In Car Electronics > Gen 2.1 how to find out what map i have |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5027 |
Haven't a clue what the latest version number is as I think HERE formerly Navteq stopped official versions years ago for the 2.1 gen, although I believe you can get third party one's, the spread sheet the quote is referring to is completely out of date.
Mon Sep 04 2023 9:40pm |
mac27040 Member Since: 15 Aug 2023 Location: Leicestershire Posts: 24 |
Have updated the map yesterday to version 20/21, it took 2 hours 45 mins to uplead with engine running but no issues. You have to get activation code. |
Mon Sep 18 2023 11:46am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 165 |
Eh up
Tue Oct 31 2023 7:44pm |
The update on a 2012 car is done via a USB memory stick, just takes a bit of time, go for a long drive or leave it idling in the drive, if you switch the ignition off the update will stop but should start again where it stopped when ignition turned back on, but you will end up turning it back on quite a few times if you do it that way.
Tue Oct 31 2023 8:34pm |
Eh up Col
Tue Oct 31 2023 9:09pm |
Plug the USB stick into the usb port in the center cubby box lid, start the car and follow the instructions on the screen which is basically enter a code which should come with the stick you have, wait 2.5 hrs or so and let it do it's thing.
Tue Oct 31 2023 9:15pm |
Eh up Col
Tue Oct 31 2023 9:17pm |
sorry not been on here for a while, i uploaded via USB |
Wed Dec 20 2023 11:08am |
