Home > Technical > RR SPORT TDV8 3.6
GerryG
Scotland
RR SPORT TDV8 3.6
Hi
Been battling with the car for over 2 weeks now. Mechanic came out and replaced the inlet manifold RH Drivers side, built it back up and it would not fire.
Long story short, codes showing up from scanner PO62 D/ E fuel injector driver open circuit performance bank 1 and 2.
Baffled as to where I go from here. Ordered a noid kit, but I am thinking there is no pulse to the injectors.
Anyone experienced the PO62D code before?
Gerry
Post #597923 Mon Apr 20 2020 11:29am
triper15
Slovenia
I have the same issue. How did you solve it?
Post #630837 Tue Feb 14 2023 10:01pm
OceanCarl
Spain
Injectors have to come out in order to replace the inlet manifold. Very likely one of the injectors got broken during this repair, either electrically or mechanically ____-Carlos-____
-2007 RRS TDV8-
Post #635536 Sun Sep 03 2023 3:18pm
Jellis39
Of some one came out and did a repair, which I assume you paid for, and it then didn’t start its down to them to sort! I would suggest either a connection issue as 1 injector wouldn’t stop it starting?
Post #635539 Sun Sep 03 2023 7:42pm
