Home > Technical > Rear suspension upper arm bump stops? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
That's quite odd that, apart from the illustration you posted there are other's in the workshop that distinctly show the bump stops, unfortunately they are not listed as a separate part in the part's list so would assume the come with or are part of the bush, I think DM might be the man to give you a answer to your question, but you would like to think if L/R say they should be there then they would be, but then again this is L/R we are talking about.
Sun Sep 03 2023 6:32am |
Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64 |
Thanks Col, yeah, I’ve had a look at the other side on my car and they’re not installed there either. I’ve looked on the internet and can’t find them available aftermarket. There are listings for the complete upper arm assembly which some show them installed and some don’t. Oh what to do??? |
Sun Sep 03 2023 10:11am |
Out of curiosity I had a quick look at my own car, not that easy to see with wheel on but it doesn't appear to have anything like that fitted either but as I say can't really see that well, it's never had arms or bushes replaced either.
Sun Sep 03 2023 10:19am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Only fitted to D3. RRS has a different design of bush, and bump stops are not fitted |
Sun Sep 03 2023 3:41pm |
Thanks guys, as always your knowledge and insight is much appreciated. Thank you for putting my mind at rest. |
Sun Sep 03 2023 9:56pm |
