![]() | Home > Technical > Ctek Charger Connection |
I think you need to connect it to the Jump start points. Be a red cover somewhere.
I connected the Neg/Live to the battery lead under the engine bay fuse box cover and the Pos/Earth to the earth stud located at same end of fuse box on the wing valance, been working fine for 7/8 years.
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 166 ![]() ![]() ![]() |
Eh up both
Not the best picture, but you will see a stud in the area marked, never actually noticed any jump lead points under the bonnet of a L320.
Eh up
In your top picture the positive is fine there, it's the same lead just at the battery terminal as opposed to the fuse box one, the negative connection is the wrong side of the BMS module.
Eh up Col
You definitely do not want to connect direct to the negative terminal with BMS. The BMS monitors the battery charge level. If you connect to the negative terminal direct it won’t see the battery charge increase and can potentially overcharge the battery (BMS thinks it’s at 70%, it’s actually at 95% and it goes full tilt trying to charge it). Same reason you don’t want to connect any accessories direct to the negative terminal, it can drain the battery and BMS thinks it’s charged.
Ehup NoExpert
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
Sorry to reopen this but, I just wanted to check something.
With a Ctek charger Yes, you leave it connected when the vehicle not being used and it keep the battery topped up.
Hi Col,
If you have 13pin or twin 7 towing electrics it can be done through there with a ctek adaptor |
As Rob says, charging through the towing electrics is another way - you just plug the CTek in to the towing point and off it goes doing its thing. No need to worry about where you are in relation to the BMS, etc., and no need to open the bonnet, etc.. That's the way I do it if I need to charge up (which isn't very often as mine gets used for decent length journeys most of the time).
