![]() | Home > General > "Restricted Performance" problem. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
If it works in the other light cluster configurations, it may be your RR does not see the brake light. This gives the same symptom like a damaged brake switch does. It may happen if the unit is a copy and not original, or the unit is damaged.
balaenamick1948 Member Since: 29 Aug 2023 Location: Minster on Sea, Sheppey, Kent Posts: 7 ![]() ![]() ![]() |
Thank you for the reply buddy, much appreciated . |
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 ![]() ![]() ![]() |
Ideally, read the codes to find out what’s causing this. Might be something entirely unconnected, eg the fuel filter water sensor can throw this message too…. |
Thank`s for your suggestions but I`m pretty sure the issue rests with the new rear light cluster. If I refit the old one problem goes away.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
It sound like you have diagnosed the problem. Is it definitely from the same model year? The pre-facelift cars had bulbs whereas the facelift have LED's.
Thank`s for your thought`s . My vehicle was registered March 2011 so probably a 2010 model and by this time (post 2009) already had the LED light cluster as standard so should be no issues with the old style lighting. The aftermarket unit I was given with the vehicle looks externally identical to the original unit but when I pop a bulb holder and look inside does`nt seem to posses the substantial PC board the original had.
So, you have found it. Or you didn't, because the PCB is not there, but nevertheless...
I think it is possible, but with much cutting and gluing which I will only try as a last resort. I still think the answer here is to be able tell the RR electronically that the new part is OK, as the new light itself works perfectly, or maybe a course of antibiotics to help with the rejection of the new body part !! |
