Home > General > Trim code location |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5006 |
Bonnet slam panel ? (Not on mine I now see)
Thu Aug 17 2023 9:51am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 419 |
Thats not it. Always listen to old people or when they die you will live on in ignorance.
Thu Aug 17 2023 2:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Don't know how accurate this actually is, never noticed a trim i.d. code plate on mine anywhere, but then to fair haven't actually been looking.
Thu Aug 17 2023 9:48pm |
Thanks col ...my RRS has been re connalised but they did not do a good job of the seat bolster and having spent hours tinting the spray for my Jag XK8 I wanted an accurate match
Fri Aug 18 2023 5:27am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Log in to Topix and enter your Vin 07MY RRS TDV6
Fri Aug 18 2023 5:45am |
Not possible without being in the trade VAT registered etc Always listen to old people or when they die you will live on in ignorance.
Fri Aug 18 2023 6:01am |
You do not have to be VAT registered or a business to register with Topix, however I believe they have updated their system and you can no longer get the build spec. for free, even if you take out a subscription I think you may find the vehicle is now to old to retrieve the info.
Fri Aug 18 2023 7:20am |
I got mine but it was a while ago. Plus it did not give trim codes as such - just listed the "marketing name" for the trim. In my case it was 'Aspen' which is the bone colour and the olive green colour - no codes or colours. To find the code you will probably need to try the good aftermarket providers of trim as they probably have relevant codes. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Fri Aug 18 2023 12:50pm |
my topix log doesn't give the trim code either.
Fri Aug 18 2023 2:21pm |
There are a few third party Vin decoder sites, however how accurate they are is another thing, as even topix isn't always correct.
Fri Aug 18 2023 10:42pm |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 161 |
I used VIN Decoderz before I purchased mine last month, for me it was spot on |
Sat Aug 19 2023 6:37am |
Just put decode VIN into Google and got a land rover vin reader and its all there Almond trim .Hooray Always listen to old people or when they die you will live on in ignorance.
Sat Aug 19 2023 7:13am |
Worth checking it then.
Sat Aug 19 2023 8:05am |
How about posting a link to the site you found, might help others lookin for spec. On theirs. Cheers Col |
Sat Aug 19 2023 9:19am |
