Home > Technical > RR Sport TDV8 Rear suspension creaking
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Thanks in advance for assistance . The offside rear suspension has a very prominent and constant squeaking/creaking noise. Air system seems to be working ok with no lights on the dash but this noise needs fairly desperate attention. Any ideas as to where to start will be much appreciated. Thanks guys.
Post #635107 Thu Aug 17 2023 12:47pm
Hub bush, likely. Can you get it to squeak by rocking the car on its suspension when it's parked? If so, that's a pretty good indicator.
The bush itself is cheap but obviously there's some work in taking it all apart. 2012 SDV6 - it's missing a couple of cylinders
Post #635108 Thu Aug 17 2023 1:55pm
Gas-guzzler
Yes, that’s right. If rocked while parked it squeaks and creaks, same when you’re getting in and out of the car and does it all the time while driving. Thanks for the help, I’ll start there and let you know how I get on. Thanks.
Post #635118 Thu Aug 17 2023 11:45pm
Gas-guzzler
Oh, and can you recommend a brand/supplier for the knuckle bushings please?
Post #635119 Fri Aug 18 2023 12:15am
Pistnbroke
First you say hub bush then Knuckles so can you be more specific in which bush and where. Always listen to old people or when they die you will live on in ignorance.
Post #635123 Fri Aug 18 2023 6:57am
Take your pick, item 17 is the knuckle, items 16 & 19 are actually described as bearings in this illustration.
Post #635128 Fri Aug 18 2023 7:33am
The one I had before with similar symptoms to the OP was numbered 16 on Col's image. It was possible to see damage on the component when the wheel was removed. 2012 SDV6 - it's missing a couple of cylinders
Post #635129 Fri Aug 18 2023 7:55am
https://www.advancedfactors.co.uk/rear-hub...-299-c.asp 2012 SDV6 - it's missing a couple of cylinders
Post #635130 Fri Aug 18 2023 7:56am
Gas-guzzler
Thanks to all for your input. I’ll post my findings to aid others in peril in the future.
Post #635131 Fri Aug 18 2023 8:15am
Pistnbroke
Thanks ..I shall check for play etc but if its just a creak they will be getting an injection through the end seals of some lubricant. Always listen to old people or when they die you will live on in ignorance.
Post #635132 Fri Aug 18 2023 8:41am
Tyrefitter
Spray some wd40 on the bush & if noise goes away,you’ll know it that. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #635137 Fri Aug 18 2023 11:28am
I tried lubricating the offending unit but it made little difference. A replacement solved the issue and peace returned. 2012 SDV6 - it's missing a couple of cylinders
Post #635140 Fri Aug 18 2023 1:36pm
Looking at a picture of the bushes they appear to be protected with a rubber boot which retained by spring clips similar to a track rod end, so unless you dislodge the boot I don't think you would be able to lubricate them very well, of course if the boot is already dislodged or split that it probably part of the issue as there has been a ingress of water and dirt.
Post #635148 Fri Aug 18 2023 10:14pm
Pistnbroke
I used the word Injection ie Hypodermic needle Always listen to old people or when they die you will live on in ignorance.
Post #635152 Sat Aug 19 2023 6:32am
Gas-guzzler
So, had a look yesterday and haven’t managed to zero in on the squeak yet but did find that my upper control arm is so corroded that it has big holes in it. Looked for a replacement on eBay and the prices vary wildly. The Britpart one seems mid priced and am thinking of going for that. Again, any recommendations would be appreciated? Thanks.
Post #635162 Sat Aug 19 2023 10:55am
