![]() | Home > Faults & Fixes > L320 HSE Harman Kardon - amp dead ? no red light |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
so bumping my own thread here with more information.
further followup - I got a fibre optic loop plug. So I was able to loop off the Bluetooth module. Still no sound.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
The only other thing in the loop is the colour LCD middle display.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
It does mention in the workshop manual about having to re-configure a replacement amp, however I don't know if this applies to just a new amp or a s/h ones as well as L/R are obviously not going to tell you that. Do you have any fault codes showing as there are a few listed for the AAM unless it's called something else in the earlier cars? which might give a clue.
So about 3 years back I replaced the Satnav screen with a Android unit - I used a fibre loop when installing to bypass issues then. I recently took apart all of that to confirm everything was connected up as per usual - and all was well. The audio for that comes out via the Aux on the headunit, it also doesn't produce any sound now though. I will certainly try looping out anything and everything at this stage ![]()
ok - so possible coding required. I need to find a suitable diagnostic tool - the one I have shows no faults or errors on scan, but I doubt its doing anything more than engine diagnostics. Any suggestions ? |
If an ecu has failed the order of components doesn’t matter.
more follow up |
Regarding the TMC and Bluetooth you can simply unplug the optic connector and bypass it either
I actually have a bypass fibre loop - so at lunch I tested bypassing both the TMC and then the Nokia bluetooth module. No difference in either case - music from CD continues to play and as each device was unplugged - on the radio - Phone removed appears briefly when unplugging either.
doing a bit more research - I noticed an L322 has the tuner part seperate.
If cds play music but radio doesn’t. It is either the headunit or the arial/amps in rear roof/or power to them
So I am back in business.
Grey ones were early versions.
