Home > General (L461) > Off road tyres |
Barnsnape1 Member Since: 31 Jan 2021 Location: Horsham Posts: 12 |
The size you are looking at is lower profile, which means a lower side wall, from an engineering viewpoint I wouldn’t normally do that if fitting an all terrain tyre.
Fri Aug 04 2023 4:52pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 267 |
The difference in circumference will mess with your Speedo calibration |
Fri Aug 04 2023 9:22pm |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 |
I'd think very carefully before going for off-road tyres on one of these. I had Grabbers on my L322 and then bought some for my L494. They were much louder on the L494 (perhaps due to not having a separate chassis) and as it's a faster/more capable road car I had some very scary cornering and braking moments in the wet when driving "enthusiastically" so I changed back to Pirellis and have never had any issues on the farm/off-roading. 2014 L494 V8 s/c Autobiography Dynamic |
Tue Aug 15 2023 1:14pm |
PhilF3 Member Since: 04 Aug 2023 Location: North Yorkshire Posts: 3 |
So I contacted Range Rover and there were no issues putting the AT3’s on. The change in size is minimal and within tolerance so no electrics or warranty affected. Yes there will be a slight speedo change but maybe 2mph at 70+
Thu Aug 17 2023 9:50am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I think the AT3 is a decent tyre. Yes, not as good on road as a full road tyre, but works well off road and has the benefit of being 3PMSF-rated too. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 17 2023 1:57pm |
