Home > General (L494) > L494 P400e or D300 or P400HST |
DrRick Member Since: 24 Oct 2011 Location: Edinburgh Posts: 54 |
So our 2017 SDV6 at 56k miles is starting to give up more times than is reasonable. It was an Approved Used, but still. We're now on the lookout for a replacement and have had all manner of LR products: FL2, Evoque, several D4s, several L494s and a D5 with the dinky engine (what a mistake).
Sun Aug 06 2023 6:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
If you're doing lots of short, local journeys, diesel doesn't make any sense these days. The DPF will hate you, for one thing. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 08 2023 8:33pm |
What sort of things are going wrong? Is it cheaper to replace or just fix what you have? Do you use an LR dealership or an independent? A decent indie will be cheaper and do a better job resulting in a happier ownership experience. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Aug 08 2023 8:36pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1845 |
Well I would go for the P400e if you can charge overnight at home for 7.5p a Kw/hr with Octopus.
So far, we've had to replace the ACE pump, the valve block for the active roll system, the main battery and now I think the suspension height sensors at the rear (front suspension isn't playing up, but the rear is).
Tue Aug 08 2023 8:39pm |
We're not on a 'clever' utility package at the moment. Thanks to the recent economic meltdown, we're one of the unfortunate lot who were on a 'decent' / cheaper supplier who went bust and we were shunted to British Gas for our sins. Now waiting to get a sensible deal somewhere that won't bankrupt us. |
Tue Aug 08 2023 8:42pm |
Have you looked at Octopus?
Tue Aug 08 2023 8:47pm |
Ah, yes, if SWMBO has decided it's not for her then that's basically it done. Sounds like you've been unlucky with the Dynamic Response system if you've needed a pump and valve block. Battery is a consumable item, frankly, once it's a few years old. Height sensors is an strange one. One going, maybe, but two would be most unusual. What's it doing at the rear? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Aug 08 2023 9:59pm |
Oh yes, the (consumable) rear flexi hoses for the brakes are due to be replaced before the MOT as they’re corroded, and the parking brake is grabbing / dragging on release. Think it’s doing the suspension back from levelling itself, and there’s an audible clunk from the near side rear and a little jerk as the car levels.
Wed Aug 09 2023 6:26am |
DWA Member Since: 06 Jan 2022 Location: Scottish Borders Posts: 17 |
Going by your choice of P400e looks like you are going with another L494, this might not be too pc on a RRS forum and I'm probably going to get shot down in flames, but reality is and I say this as a Land Rover pervert of 30 ish years, but how long is another L494 going to solve your problems for. I know loads are running every day and never put a wheel over a garage door, but I also know mine has it's fair share of problems as do loads more and so has every Land Rover I have ever run from Freelander to RRS and every one in between. Just putting it out there as food for thought after all that's what these things are all about. |
Wed Aug 09 2023 11:09am |
We've had a bunch of LR products....and one BMW equivalent. We're also well scarred by the fact that LR vehicles have high bork potential....yet we still come back.
Wed Aug 09 2023 11:21am |
I know the problem, had enough of Land Rover a few years back and went to the dark side and bought an
Wed Aug 09 2023 12:10pm |
The new LandCruiser very much doesn't compete with the RRS, however. It's aimed at those that need/want off road ability and the ability to modify it for serious off road use. It's not competing in the luxurious, off road-capable, sports-limo category in which the RRS really finds itself. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 09 2023 1:08pm |
Indeed, my formative years were Wadi Bashing in Oman in the back of a Nissan Patrol. Group of like minded expatriates, no plans, no emergency cover, limited resources but it just worked. It was desert, rocks and heat.
Wed Aug 09 2023 1:55pm |
