Home > Technical > Coolent level low light on |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 245 |
Hi , no you will need to drive the car for abit and this will clear the stored code.
Thu Jun 01 2023 10:04am |
Barry webb Member Since: 01 Jun 2023 Location: Cornwall Posts: 10 |
Thanks for your reply I've been driving it around fir about a month now and its coolent level is good but light still stays on. |
Thu Jun 01 2023 10:48am |
Ah okay!
Thu Jun 01 2023 10:50am |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 |
Hi if there are no leaks now and the coolant level looks fine the level float in the expansion tank is saturated and sinks to the bottom.You need to change expansion tank. |
Thu Jun 01 2023 4:30pm |
I have disconnected the battery for 30 mins and on reconnecting the warning light is still on I have two cheap plug in hand held machines and both say no codes to clear. |
Thu Jul 20 2023 2:42pm |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 150 |
Sticking float switch in expansion tank, quite common!!
Thu Jul 20 2023 4:49pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 |
As above. New expansion tank (with sensor) needed. Barrie.
Fri Jul 21 2023 5:56am |
Hi I have the tank with the small push in sensor.
Fri Aug 04 2023 7:37am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Did they replace the sensor or the whole float unit? If the float sticks down, the sensor can't give any reading other than low. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 04 2023 9:43am |
Hi there is no float system it's just a tank with a stuck like sensor. |
Fri Aug 04 2023 2:53pm |
There is deffo a float after time it becomes saturated and sinks to bottom of tank causing the alert.Replace the tank problem solved. |
Fri Aug 04 2023 3:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4982 |
Float is part of the tank.
Fri Aug 04 2023 3:24pm |
Hi I have spoken to the with the guy doing the job for me and he confirmed there is no float in the tank only the push in sensor that he has replaced with a genuine part see picture of the sensor. |
Fri Aug 04 2023 4:04pm |
Well it must be stuck on the bottom but there is deffo a float that moves up and down with the level as said they become saturated and sink to bottom.The tank itself cones with a sensor when you buy new one .The tank itself is easy to replace. |
Fri Aug 04 2023 4:47pm |
