Home > General > No crank no start, lights flashes on the dashboard
Willie T
Hi Guys
I'm new to this forum. I have a 2008 RRSport that I am working on, it's acting up, lights flickering, no crank no start and there is also water on the front passenger floor. Any help from you guys will be appreciated.
Post #634695 Mon Jul 31 2023 4:53pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
is your vehicle right or left hand drive? if rh, then is suspect you have water ingress hitting the fuse box. also remove battery & check ecu for water damage.
Post #634731 Tue Aug 01 2023 10:53pm
Willie T
Thanks for your reply.
It's left hand drive.
I remove the starting kits (key, ECU, dashboard, fuse box, immo ring) and put it on another RRSport it works perfect. No lights flashes, everything works normal.
Post #634750 Wed Aug 02 2023 1:36pm
TheWojtek
1. Water ingress around the base of the right-hand (passenger) A-pillar.
2. Faulty battery/ground connection. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #634751 Wed Aug 02 2023 2:01pm
Willie T
The battery is good. Is there any ground underneath this seat?
Post #634753 Wed Aug 02 2023 3:39pm
TheWojtek
Here's an example: https://www.facebook.com/JASLandRoversLtd/...55/?type=3 Regards etc.,
Wojtek
Post #634755 Wed Aug 02 2023 4:39pm
Willie T
Thanks for your help.
I forgot to mention this; there's also an E on dashboard, there's no P on dashboard but E.
Post #634760 Wed Aug 02 2023 6:15pm
Willie T
These are the lights flashing on the dashboard
Post #634761 Wed Aug 02 2023 6:22pm
TheWojtek
An E stands for gearbox error.
It seems to me you have a major f***up in the CAN bus. If you have water in the passenger footwell, this is where you need to focus on and find whatever damage the water has done to the wiring harnesses. Regards etc.,
Wojtek
Post #634765 Wed Aug 02 2023 9:29pm
Willie T
Thank you so much for your help.
I will keep you posted on any development.
Post #634770 Thu Aug 03 2023 7:32am
Peter tarabay
Kuwait
Hii sir i have the same problem of the photo that you posted
Hii sir i have the same problem of the photo that you posted Please can you share the solution?
Post #643493 Sat Jul 27 2024 11:39pm
