Home > Maintenance & Modifications > Nut for holding license plate on tailgate
ax_crosser
Belgium
My L320 (2009) is missing a nut in the tailgate where the license plate can be bolted on to. The hole seems to have a hex-shape.
Can someone tell me what nut/rivnut/partnumber I need?
I am only missing one, but a previous owner put in a regular "round" rivnut which does not have a nice fit. So I want to fit OEM ones again for both.
Post #634556 Wed Jul 26 2023 9:59am
Dave B
It's a perfect place for water ingress, resulting in rust which will make removing the screw difficult at a later time, which is more than likely what has happened here.
Make sure the hole area is clean, cover with some quality 'gaffer' tape, and use sticky pads to fix the registration plate on.
That's my suggestion, and the way I do it.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #634557 Wed Jul 26 2023 10:08am
DYH000140
Post #634559 Wed Jul 26 2023 10:25am
ax_crosser
Belgium
a plastic one? that's original?
Post #634560 Wed Jul 26 2023 10:45am
Plastic would be original. Then screw in a metal self tapping screw
Post #634563 Wed Jul 26 2023 11:55am
