![]() | Home > Faults & Fixes > Central locking |
I had the exact same issue,, apart from changing the battery, then started having trouble locking any of the doors and also alarm randomly going off which I eventually found to be the bonnet switch. Bridged it out for a while and it just about fixed the locking issue and no random alarm. I still think there is still an issue with the drivers door latch though as sometimes if I double press I can hear the latches operate but the mirrors do not fold in which they normally do when double locking. If I press to open then close again the the latches drop and mirrors fold. I'm sure the drivers door latch is a known problem as they get older. 2010 RRS, TDV8
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi appreciate response I sat in car door closed and activated the locking with fob. I noticed the internal lock unlock switch didn’t move fully and I needed to push it a bit to manually put in in its fully closed position .I think I need a new actuator mechanism as it looks like mine has gone faulty |
Hi folks quick update it’s working now for some reason !!! I locked it by the handle button pressed once twice did this 3 times each time locking fully.Then tried key fob and locking also WTF I have an actuator on order but no logic !! any ideas why it should start working again |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Temperature affects them! |
It’s weird witch 🧙♀️ craft and magic I say mmmm must admit the other half’s broomstick is looking weird lol first Land Rover I have had and love it but I certainly think owning a Land Rover and logic don’t go together well lol 😂 |
