Home > In Car Electronics > DAB "no reception"
clarker63
England 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
DAB "no reception"
Hi I know this appears to be a common fault, and I found a post saying just to replace the DAB unit so I tried that but it didn't help - I've got exactly the same problem, so either both are faulty or its a different issue altogether!
I've found the component location diagram in the workshop module. Item 20 (FM2/DAB3/VICS antenna amplifer) appears to do both DAB and FM (which is working in mine). Could it be this that is causing my DAB issue?
Any help very much appreciated!
Thanks
Rob
Post #630851 Wed Feb 15 2023 1:38pm
TimColman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Baltic Blue
Hi Clarker
Have you had any joy? I've lost DAB and TV since a battery change. I'm searching high and low on the interweb for clues but with no luck yet. If I sort it out, I'll post here.
Post #634342 Mon Jul 17 2023 5:24pm
Jellis39
I had a couple of internal module faults. Fitted a replacement module today and no codes, but there is still no dab signal! Does anyone have a pic of the DAB amplifier unit? I’m wondering if it’s possible to fit a stick on aerial which would plug into the dab module.
Post #634346 Mon Jul 17 2023 9:44pm
Jellis39
Is this the aerial amplifier unit?
Post #634347 Mon Jul 17 2023 9:46pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
I had no DAB for a while in our Evoque. Told it could be a profile issue. Deleted profile from car after signing out from inControl. Turned off/on again and recreated profile. Parked car in guaranteed good reception area (full bars) and waited patiently. After about 10 mins all DAB stations re-appeared and have stayed ever since.
Worth a try?
Post #634349 Mon Jul 17 2023 11:23pm
clarker63
I gave up on the DAB issue. Yes I believe the fault is the amplifier - but the consensus appears to be that the DAB radio is rubbish anyway, and I can stream any content from my phone through a BT adapter/aux socket. Hence I didn't proceed with trying to fix it. If you get it fixed please post the results.
Note that I have found the FB L320 group way more useful/active than this website....so I hardly ever come here.
And inControl appears to be something new which I am not sure are on anything before a major OS upgrade for the ICE. Certainly there's nothing like that for my 2010 facelift model.
Post #634354 Tue Jul 18 2023 9:55am
clarker63
Having spent a bit more time looking for it on the interweb , its really confusing... none of the adverts I can see have "DAB" in any of the titles. and there appear to be many different amplifiers with different part numbers... have you managed to get yours out from under the roof lining? there are two so worth googling those part numbers to see what you can eventually work out is the DAB one....
Post #634355 Tue Jul 18 2023 9:59am
Jellis39
I haven’t. I hoped the new module would sort the issue, which it hasn’t! I then found a bit of info about plugging a normal dab aerial into one of the aerial connections on the module, but it still won’t work. I’m not spending any more time on it and will just use phone linked to aux.
Post #634371 Tue Jul 18 2023 7:42pm
clarker63
call me stupid, but I decided to look in more detail.
so there are two items in mine. the grey one you showed and the blue one.
the part numbers appear to be meaningless on any Land rover spares website (WTF) - looking online the blue part appears to be XUI500071, but again I am not sure.
I am split on which one does what as nowhere I can search for has a specific description, just "amplifier".
I could order both, the slight risk is that the one you get is broken also as this is a common fault... but I'm tempted to try both, just to see if it fixes it. £26 on a range rover is paltry... Wink
I'll order them and see.
Subsequently I've spotted another image, if this is true (haha), item 6 is the DAB one - which relates to the grey one in my picture. I'll try that one first I guess... What an awful piece of documentation!
Post #634386 Wed Jul 19 2023 1:40pm
Is that the passenger or drivers side photoed?
Other one does the radio I expect.
Turn the radio on the FM. Pull the power connector out. See if radio stops or goes mono
Post #634395 Wed Jul 19 2023 6:04pm
clarker63
yes, passenger side. I have contemplated doing that. But I'll do it when I have both replacement parts to hand. I don't think I've ever seen such awful technical documentation. strange that there appears to be FM aerials and amplifiers both sides (I've not checked the driver side to prove whats over there.. but I might just for completeness).
Post #634397 Wed Jul 19 2023 6:26pm
My drivers side had lost power, and the FM was just mono
Post #634398 Wed Jul 19 2023 7:34pm
Looking at a old Microcat epc, the the DAB amplifier is the grey one part no. LR016258 on Vin No. up to BA999999 fitted on the N/S, from Vin No. CA000001 on it is L/R029702 and is fitted on the O/S assuming the illustration are correct.
Post #634404 Thu Jul 20 2023 12:58am
clarker63
thanks for the replies. I bought the grey part but no joy though. Exactly the same (No reception on DAB2). I had already replaced the DAB unit (behind the drivers side/boot rear trim). Even if I leave the amplifier completely unplugged there's no change to the status on the screen.
I half expected this but I thought it was interesting to have a go. Obviously I'm a glutton for punishment (although I know this is a simple task vs most on a Range Rover, so I mustn't complain really)
I hate removing the headlining - it always gets creased and dirty whenever you do these sorts of things.
Definitely not worth trying IMHO just rely on streaming.
Post #634447 Fri Jul 21 2023 12:56pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Hello,
Did you fix your DAB issue?
I'm currently chasing down DAB 'no reception' also.
Would you be willing to have a chat possibly, I also feel mine is MOST related, even though I have replaced the DAB module in the boot and in the process of swapping over DAB/FM antennas for used ones to see if it does the trick. I also have a new DAB/GPS antenna for the roof to fit this weekend too.
I have other issues also, those being DVD player not working (6 disc) in the boot.
If your willing Id give you a ring, if possible? far easier than typing on here, and wondered if you might of gotten to the bottom of your problem yet.
Let me know
Dean
Post #642884 Thu Jun 27 2024 7:26pm
