![]() | Home > General > Changing odometer from KM to miles |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
I believe SDD can switch it to miles when ran in engineering mode (full access to CCF). I personally wanted to do the opposite (my dads D3 comes from the US of A), but sadly there is a fault in the BCM of this very car preventing the CCF from being edited so never really got to it. Regards etc.,
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Thanks Wotjek - will investigate with my local indy. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Not sure you have to edit anything in the CCF, don't know if you can do it via the indicator stalk menu on the pre-facelift, but simply change mine on a facelift with the steering wheel menu button.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
On my 2005 I can do it as per Col's post. Barrie.
Thanks Col - I can change the trip from km to miles on the main display, but not the small display to the right of it, which gives the total distance travelled. |
Perhaps it is only the facelift you can change it all on.
Incidentally - thanks for “The Poznan” ! |
No is the same for earlier models. Its all in the handbook. If in doubt, read the instructions. 07MY RRS TDV6 Arctic Frost Aspen Interior |
That's why I posted the settings option pages for the pre-facelift cars, as the OP may not have one.
Exactly. The units for the central information display are easily changed with the "i" button on the stalk. The units for the odometer (the small display below the speedo) are fixed - however there is a position in the CCF that sets default distance unit for the whole car.
Haha, I can see what you did here ![]() Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Thanks Wotjek - so it’s definitely a case of going into the CCF ? |
I'd have to sort my dad's BCM to be 100% sure, but I was playing with the CCF in my car when switching to digital cluster and when I set "mph" as the global measurement unit (not the secondary small speedo), my odometer started to show the mileage in miles as well. Regards etc.,
