Home > Technical > oil pressure gauge port
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
3.0 Diesel, is there a point where a pressure line can be tapped into on the engine close to the oil pump?
Theory is to have a discreet oil pressure gauge to keep an eye out.
Alternative is to use the oil pressure reading from OBD port but im not sure where this reads from.
Post #633818 Mon Jun 19 2023 9:35am
not available on OBD
Post #633828 Mon Jun 19 2023 3:36pm
Crraigymmmmm
Thanks Andy I can see it on my Diag app but agree, I cant find any with a gauge with a ODB plug so will have to go for a new pickup position,
Found a discreet place to locate a small gauge so not to ruin the OE look and get a small loom to the engine bay but pick up point the pressure is my concern.
Ill do some research and feed back.
The reasoning behind this is to hopefully spot any potential oil pump issues as they happen rather than after the noise starts Big Cry Plus its time to start a new project - the devil makes work for idle hands.
Post #633836 Tue Jun 20 2023 8:51am
Most people make an adaptor, to plug into the original port ontop of the head, at the front.
The video shows this.
Post #633837 Tue Jun 20 2023 10:54am
Crraigymmmmm
Yeah Sorry, I have watched that now, very easy job then, Just gotta find a more OE looking gauge
Ill do it with fittings rather than a mani block but will post some pics.
Post #633838 Tue Jun 20 2023 11:43am
erickwan
Malaysia
Search for LRTime on YouTube
Post #634096 Tue Jul 04 2023 2:17am
Pistnbroke
Sorry posted twice Always listen to old people or when they die you will live on in ignorance.
Post #634855 Sun Aug 06 2023 7:26am
Pistnbroke
Electric oil pressure gauges are notoriously inaccurate ..better to have a mechanical one with a pipe.
The OBD will not read oil pressure as there is no sensor on the engine..only an oil pressure SWITCH. Always listen to old people or when they die you will live on in ignorance.
Post #634856 Sun Aug 06 2023 7:30am
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Is there a way to fit a pressure gauge to a TDV8 at all
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #634882 Mon Aug 07 2023 7:20am
Pistnbroke
You need an adaptor (loads on ebay) to go in the oil pressure switch hole but as I dont have a V8 I cannot look what space you have Always listen to old people or when they die you will live on in ignorance.
Post #634883 Mon Aug 07 2023 7:55am
