![]() | Home > Faults & Fixes > L494 Sunroof and sunroof blind |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 ![]() ![]() |
I have a Feb 15 (pre facelift) RRS 3.0 SDV with pan roof
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 248 ![]() |
Maybe disconnect battery for 10 minutes and reconnect might help clear any fault code. |
Thanks - I’d be |
Great call on the fuses - I’ll try that. Don’t suppose u know which number fuses and which fusebox? I’m at work and could have a crack at this before I go home
Not sure pal, google fusebox locations l494 and you should find something. |
Russtyp Member Since: 13 May 2022 Location: Caerphilly Posts: 19 ![]() ![]() |
There are two fuses in the passenger fuse box.
Pulled the fuses, still no joy. Fek. Got a feeling this is going to be messy |
