![]() | Home > General (L461) > Massive ‘hair drier’ noise from the engine when charging |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Battery needs cooling down while charging. Not so apparent in winter, quite noticeable in summer. Regards etc.,
Cantona Member Since: 27 Oct 2015 Location: Cheshire Posts: 518 ![]() ![]() |
Many thanks Wojtek. |
Claud Member Since: 26 Sep 2021 Location: Surrey Posts: 7 ![]() ![]() ![]() |
I had the same issue a couple of days ago charging the car with a car cover on. The cover blocked the air intake on the front and subsequently the cooling fans went into a spiral of faster and faster rate. As soon as I removed the cover off the front of the car, the fan rate dropped.
