![]() | Home > Technical > 2nd battery in LH rear quater panel |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Shows O/S but nearside the same except no loadspace lamp to disconnect, can be a little easier if you remove the two lashing eyes bolted to the floor and remove the small floor carpet panel but not absolutely necessary. Not much room behind there to fit a second battery of any capacity though.
